Solar Battery backup
Energy saving questions in here please
alfier
Has thanked: 13 times
Post by alfier »
I need a battery backup system for my PV 10Kw system comprising 2  5KW inverters.
Can one of you advise me on best and cost effective AC/AC to add to existing PV please?
Alfie
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
alfier wrote: Sun Sep 05, 2021 8:24 am Can one of you advise me on best and cost effective AC/AC to add to existing PV please?
Don't you mean a AC/DC system i.e. a charger? This will require us to know what your load requirements are i.e. how long you want to run the inverters for (which depends on the load) which decides the size of the battery bank which decides the size of the charger etc.
alfier
Post by alfier »
THANK YOU for your reply. my solar panels feed 2 x 5kw DC to AC units. I would like to add batteries to allow the batteries to use the batteries during the night when only Fridge and 2 computers running dependent on cost.
I hope that's enough to help you to help me.
alfier
Post by alfier »
I was hoping for an answer as :dunno:
Has thanked: 47 times
Been thanked: 2590 times
If you only want it to run a fridge and two computers, will the batteries not cost more than you could ever save?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
I expect to get ridiculed for this: my Igenix 92L small standard fridge is rated at 110kWh/annum, that is average 12.6watt/hr. A deep cycle lead acid 12v, 50amp/hr leisure battery, supplying an inverter at 80% efficiency would run the fridge for about 19hrs before it reaches 50% discharge, lower and it will have a short life.
Now the problem with compressor type fridges is they cut in and out and their start ampere can be up to 7x times their rating; my 600watt inverter with a 1200watt overload cannot consistently power up my fridge without tripping. A fridge which is absorption cooling type has a chance as it does not have a heavy compressor but at fan. My 40L Caldura at 65watt runs nicely but even if it runs 6 times an hour it will consume 11 watts much the same as my 92L.
Add 2x modern laptop computers @ say 2x30 watts, (my old laptop uses 40+) making assumption they are using continuous power these would eat the same battery down to 50% in less than 6 hours, but better if their cooling fans don't kick in.
Now to get a better time you need to consider Lithium batteries!
I installed the inverter to power my CH should there be a power outage and it works fine for that, but not the fridge and most certainly not for the freezer.
Oh and you might need pure sine wave inverters for computers.
The other problem in getting a battery down to 50% is that my inverter will give warnings as the voltage input drops and will stop at about 10.8v dc !
kellys_eye
The batteries required would need to be the equivalent of the power you intend to use +30-50% (to prevent over discharging).
Add up the wattage of the devices you want to power and then multiply that by the number of hours you want to run them for.
E.g. Fridge ~120W, 2xPC's @ 150W each - total is 420 watts. To run them for 12 hours means 12x420 = 5040W. Add on the 50% margin and you;re looking at 7500W
Divide this number by the voltage of the batteries you plan to use (you don't state whether it is a 12V, 24V or 48V system) to get the ampere-hour capacity you need.
7.5kW of batteries is a LOT. A bank of 12V batteries would need to be rated at 625Ahr..... Given that a 'large' 12V battery is typically 110Ahr you'd need 6 of them in parallel. Not impossible, of course. But we don't know what voltage your system is, nor do we know if you have the appropriate charger for the intended batteries - they have to match.
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Post by Chippo1 »
Maybe u need to consider a new Hybred invertor and lithium batteries with deep discharge capacity the two 3.5KW batteries I have discharge down to 5% but they cost around £1k each made by a firm called Pylon
alfier
Post by alfier »
Sounds like what I want. Please send me more details.
Alfie
Chippo1
Post by Chippo1 »
Try Googling Pylon batteries , sold the world over , avsilbe here on net and midsomer wholesale, one problem is they are in short supply at the moment , seen the 3000cs batteries I have at £1400 each. Think retail from Midsomer is £1300 ish with delivery in may
I have a Sofar inverter which they also sell
alfier
Post by alfier »
Got a bit lost sorry. can you give me the web site and advise how the inverter and batteries are wired in
Alfie
ericmark
Has thanked: 118 times
Been thanked: 783 times
Post by ericmark »
My fridge/freezer and freezer are powered with a three phase motor through a inverter driver and it seems to have a very small inrush. The biggest load is when it goes to defrost, so around 160 watt.
Return to “Energy Saving”
