Stanley FatMax Pro-Stack Deep Box £20
- Argyll
- Has thanked: 1180 times
- Been thanked: 576 times
Apparently these are compatible with DeWalt's tstak boxes.
https://www.toolstation.com/stanley-fat ... fCPqYo15Tg
- etaf
- Has thanked: 37 times
- Been thanked: 146 times
The fatmax organisers , mine PRO version do not fit the Dewalt T-Stak
I have these
https://www.toolstation.com/stanley-fat ... ser/p80453
various , purchases via scrwfix, toolstation and amazon when on offer
I have some deep and some shallow versions - all called PRO , some with the full metal locks and some with plastic locks, NONE of them will fit a T-Stak
I had to buy some of the dewalt organisers , which were on offer at screwfix for under £20 to use with my T-Stak system.
So it may be worth just checking
If i purchased that box, i would want it to work with my Stanley Pro organisers
I have these
Simple DIYer
Wayne
Wayne
- Argyll
Apologies I was given incorrect information. Apparently, they are not compatible with the tstak boxes.
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2333 times
they actually look identical ridges furrows lugs 3 folds in the metal catch in the centre 45%
slip in clear plastic window above and the same length as the lid lock rebate
very square handle with a moulded central section soft material on the stanley but same material on the dewalt with a groove all round to give definition to look like a soft grip area
joining clips on top identical looking [in the closed position] but different colour
- etaf
my stanley pro box distance between the sides and connectors , is very slightly longer then the T-Stak distance across the connectors
The stanley pro connectors are also smaller in width then the T_stak
tried to take some photos
I lined-up the Pro box on 1 side of the T-Stak, and photographed, then photographed the other side
3rd photo i put 2 stanley pro's clipped together and tried to photograph that ontop of the t-stak
not very clear
not very clear
- Side lined up.jpeg (65.43 KiB) Viewed 4624 times
- Opposite side when aligned on left.jpeg (35.83 KiB) Viewed 4624 times
- 2pro stacked and aligned with t-stak.jpeg (36.04 KiB) Viewed 4624 times
Simple DIYer
Wayne
Wayne
- big-all
- Pro Carpenter
quite surprizing really if you want to reduce prices you share injection moulding moulds as they cost several thousand often millions off pounds each
but to make a near identical but a fraction different is quite surprizing
- etaf
Especially as Stanley/Dewalt are all the same company Stanley Black & Decker
I guess it keeps you in the brand, as i mentioned I have now purchased 2 dewalt organising, which i would NOT have purchased if the stanley pro had fitted onto the T-Stak. they were on offer at toolstation with a dewalt toolbox , can not remember the price £30 ish for both, as i used it a lot I then purchased a 2nd one at screwfix for £19 which was under the half price , I think it went to almost £45 at one point.
Now both are attached to T-Stak cases if i have to take anything to my daughters, much easier to carry
Like the stanley pro , they come in different waterproof versions, with seals. the pros come with seals and metal clips or no seal and plastic clips, which at the time i had not noticed, and at the time screwfix had a deal buy1 get1 free, which the sales assistants, was asking everyone if they wanted, clearly they had a lot in stock to shift.
So with subsequent purchases I had to be careful, that the bargain price was in fact for the same product, and not the "inferior" (wrong word) version "Like for Like".
Simple DIYer
Wayne
Wayne
- big-all
- Pro Carpenter
i wonder if its a tooling mistake
as in new mould or extra molds ordered but made to the wrong specefication so another use had to be found
- Argyll
