Which part of this LED light needs replacing?
anderton46
Has thanked: 1 time
Post by anderton46 »
So the bulb went in the bathroom and I figured it'd be some sort of bulb but I've been met with this.
The ring of LED's isn't totally dead, however it is giving off an incredibly low level of light. So I'm not really sure what needs to be replaced. Is it the 'LED Driver', or will it be the ring of LED lights that has gone?
Any help much appreciated. I've found a few videos on youtube telling me how to change the various parts, but I don't know which piece it is that is defective.
thanks
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Sadly, nor do we! It's a case of swapping one or the other out to see which is defective - unless you have the test equipment to make purposeful measurements.
Either way, spares or a test meter will likely cost as much time/trouble as replacing the whole unit.
One chance - if ALL the LEDs are of the same brightness then I'd go for a new driver module. Check - very, very closely - the individual LEDs and look for tiny black spots which indicate failure. If you see any then a new light is the only way to go as fitting individual LEDs is a pointless waste of time/money.
anderton46
Has thanked: 1 time
kellys_eye wrote: Tue Oct 19, 2021 12:54 pm Sadly, nor do we! It's a case of swapping one or the other out to see which is defective - unless you have the test equipment to make purposeful measurements.
Thanks for the response! So theres maybe 15/20 LED's all of them are the exact same dim level of brightness except two which are out. Would that lead you down the path of just replacing the whole unit?
thanks again :)
Has thanked: 47 times
Been thanked: 2590 times
The question should be:
How much is a new "LED Ring" and can you get one the same voltage
How much is new driver
How much is a complete light
My money is on the "light ring" but if I am wrong............. Change the whole light
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
My recommendation is to replace the whole unit with user changeable bulbs
Return to “Lighting”
