Oven Wiring
Posted: Mon Oct 25, 2021 7:46 pm
Hi All,
I’m in need of a new built in oven. Best options for my needs all seem to come with standard 13A plug.
The current oven is hardwired to an Isolator Switch which contains a 13A fuse and is on its own circuit in the fusebox.
Question is can I simply replace the isolator switch with a standard plug socket to accommodate a new oven with a 3 pronged plug?
Or alternatively just remove the plug from the oven and hardwire in?
