Plasterboard fixings
chippyal66
Has thanked: 4 times
Post by chippyal66 »
Whats the recommendation for plasterboard fixings for wall units. So many to chose from at the moment
I need to hang some wall units and its like papier mache. Its an 80s build, would have considered cutting out and adding some timbers between the studs but as its internal theres nothing to fix to, centres are at 600mm
any advice is welcome
fin
Has thanked: 32 times
Been thanked: 805 times
Post by fin »
gripit fixings from toolstation ive used in the past
have you considered a hanging rail?obv ya might have to notch the cabinets a bit on the gables to allow the rail to pass through them all..... or have the cabinets slightly forward and packed off the wall at the bottom....
These users thanked the author fin for the post:
chippyal66 (Wed Nov 10, 2021 10:47 pm)
London mike 61
Has thanked: 285 times
Been thanked: 402 times
Post by London mike 61 »
Forget the plasterboard fixings, use a cabinet rail and screw to the wall studs.
This is a example but there may be cheaper suppliers
https://www.google.com/url?sa=t&rct=j&q ... cKtslK0mjg
Mike
Ps sorry fin, I’ve just seen your post !
These users thanked the author London mike 61 for the post:
Return to “Kitchen Fitting”
