Hardwired TV Splitter/Booster
liamus
Has thanked: 4 times
Been thanked: 2 times
Post by liamus »
My TV aerial splitter and booster in the loft has stopped working and I need to replace. All the ones I have seen come with a standard plug however mine in the loft has been wired in to an unswitched fused spur - anyone know why?
Anyway, can I just removed the plug from a new booster and wire into the spur?
Has thanked: 48 times
Been thanked: 2608 times
liamus wrote: Sat Nov 13, 2021 2:26 pmanyone know why?
Probably because they
liamus wrote: Sat Nov 13, 2021 2:26 pmremoved the plug from a new booster and wire into the spur
(Edited to add the line below, then edited due to TYPO)
FWIW All "Appliances" for the UK must come with pre-installed plug.
liamus
Post by liamus »
ok
Return to “Electric Forum UK”
