sand and cement render in bathroom
Posted: Tue Dec 28, 2021 12:41 pm
Hi guys,
As with most jobs get stuck in and things change.
Its a 1930s house and I’m working on bathroom.
Its tiled around the bath, the rest is painted plaster with its fair share of cracks and hollow sounding plaster. Plan was to remove the lot,dot and dab boards up then tile floor to ceiling all four walls.
What I’ve found is the top half of the wall the plaster/render literally just fell off, and crumbled away back to brick/block. The bottom half looks to of had a new layer of sand and cement and it is solid, there’s literally a line from old to new and the cracks where all in the old section.
Now I can’t decide what’s the best option , Should I just sand and cement the top half to blend in with the lower? Or try to get it off and board the lot? I’ve added a couple of pictures to see the different layers that I’m working with, some sections are really thick 15/18mm other under 10mm.
Any help/ideas much appreciated!
