Hi
Can anyone recommend a good diamond drill bit for porcelain tiles
Drilling porcelain tilrs
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Smaller holes are usually done using tungsten carbide but larger, diamond-coated by Erbauer have served me well.
- geralds (Sat Jan 01, 2022 10:16 am)
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
The main issue is that drills are too slow and burn the bits up
If you have a grinder go for a compatible bit it will last much longer
https://www.toolstation.com/mexco-diamo ... lsrc=aw.ds
