Black Mould under Paper
Miketatt
Post by Miketatt »
Hi guys,
Just hoping for some advice on how to proceed. I’ve just bought my first house and was planning on doing a quick paint job in the spare room. I noticed some cracks in the surface of the wall and it sounded hollow underneath.
I started to peel off what appears to be paper that’s been painted over and have found this: see attached pic.
It appears to be black mould?
Do I need to just rip all the top layer off, treat the mould and then repaint? Or will it require something more?
Thanks in advance.
Mike
wine~o
Has thanked: 1415 times
Been thanked: 4031 times
Post by wine~o »
Difficult to tell from the pics but that looks like a thick thermal wallpaper. Probably used to solve the mould problem in the first place.
EDIT :welcomeuhm:
ahfix
Has thanked: 61 times
Been thanked: 184 times
Post by ahfix »
If you clean the mold off is there paint on the wall surface?
Mold forms due to condensation coming in contact with a cold surface. In that case you might want remove the paper and clean the wall with a bleach solution to kill the mold first and after that you could paint with an anti-fungal paint Zinsser perma white. There maybe coloured version available.
I bet that room is cold so personally, after the above I'd line the walls with a thermal paper at a minimum or better still 25mm kingspan/celloex with foil to tape the edges and joins and then plasterboard over. It may seem a lot of work but a competent DIYer could do it or a dryliner/joiner in a day. That'll solve the mold issue and make the room warmer.
ah
