Tools to give sealant a good finish
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Cannot recommend any particular tool, as I've never used one - after forty years of trying, I can get a good finish without.
But if you search google, amazon, screwfix, toolstation, wickes for sealant finishing, caulk finishing, sealant smoothing and similar tools you will find HUNDREDS of versions, all much of a muchness. The Vitrex one looks good.
The trick I use, with an old credit card cut to the shape I want (or most often simply my finger), is a spray mister bottle filled with a weak solution of detergent & water. Mist copiously and smooth to shape.
I detest the job, never look forward to doing it, but once I get going I rarely fail. Also, I use good quality sealant, usually hybrid, such as Soudal Fixall for instance.
No doubt there'll be alternative views put forwards.
- These users thanked the author arco_iris for the post:
- London mike 61 (Tue Jan 11, 2022 8:30 am)
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2559 times
Silicone squeegee's
You use the corner of which ever one is best for the job you are going to do, no water, washing up liquid etc req.
(Available from several suppliers and ebay)
- geralds (Mon Jan 10, 2022 11:47 pm)
- etaf
- Has thanked: 37 times
- Been thanked: 146 times
just a DIYer
i have used these in the past
Cramer Fugi Profiling Tool
I managed to get a 7 piece kit from here, they were over £20 on amazon a while back
https://www.plumbworld.co.uk/cramer-pro ... s8QAvD_BwE
after watching these videos
https://www.youtube.com/watch?v=_DI4hfHM_Hg
used a few times and had some good results
Simple DIYer
Wayne
Wayne
- Has thanked: 61 times
- Been thanked: 184 times
I've bought the long handled style of smoother in the past and didn't get on with it.
I agree the Cramer Fugi is the best tool out there.
ah
ah
- Has thanked: 32 times
- Been thanked: 805 times
fugi kit for me.
or spray bottle and your finger. spray your fingers with the water also.. basically anywhere you dont want the sealant to go
dont cut the nozzle at an angle cut it straight. say if you are sealing a vertical corner on a tiled wall so both surfaces are tiled.... keep the gun level and bang int eh middle so at 45 degrees. take a steady pace and dont put too much on. try not to stop and start again
- These users thanked the author fin for the post (total 2):
- London mike 61 (Tue Jan 11, 2022 11:48 am) • geralds (Wed Jan 12, 2022 9:17 am)
- Rating: 14.29%
