Hello
I have some paving slabs that were laid about 15 years ago. Pic included.
As you can see it is a state of disrepair and I would like to tidy it up again.
How best to do it ?
Do I dig it up flatten and relay on soil or do I put some sort of hardcore down on top ?
I would like to make it look neat
How do I ensure that the slabs do not move again
Paving slabs in Front of Shed
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2590 times
I would look at This place
- Has thanked: 285 times
- Been thanked: 403 times
I’m going to assume that you are going to reuse the existing slabs which are a mish mash of broken whole slabs of different sizes.
So I would take them up and dig the site to a depth of around 5 or 6 inches and start with a good layer of type 1 mot ( which is crushed concrete ) then cover that with enough sharp sand to just about cover the chippings. On top of that layer put a weed suppressing landscape membrane then a layer of sharp sand to lay the slabs on but in a crazy paving pattern. Fill the gaps with a 5 to 1 sharp sand /cement mix not too wet.
Or you could scout around your neighbourhood for skips with discarded bricks and omit the sharp sand layer and lay the bricks on a bed of mortar in a pattern of choice.
Mike
Mike
- newdud (Tue Feb 08, 2022 8:15 am)
