Canny deal as Fin would say
https://www.powertoolmate.co.uk/deals/d ... attery.htm
DeWalt 54v 6ah battery £90
- Argyll
- Has thanked: 1180 times
- Been thanked: 576 times
- Argyll
Promo code PB5 takes 5% off so they work out £85.49 each.
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2333 times
that really is a good deal
its back to the pre covid /leave the eu level where they where £88 without fail at all sources but a bit expensive for 18v as at the time the 4/5ah where between 10-11 per amp as in 4ah 40-44 5 ah 50-55 so overpriced as in £176 will get you 12ah in 6amps but 3x5 in 5 amps so 15 amp for£150-165
buutt with new tools using battery groups in the battery, in parallel you can get greater power from a 54 battery than a 18v battery for new 18v tools
