Sticking door (after settling?) how to fix.
We had a loft conversion done 2 years ago.
The builder turned out to be a bit of a %$£@ - so I wouldn't go back to him even if I could.
I don't know if its normal for this to happen - but the door to the little bathroom no longer closes. Its too 'tight'.
I tried sanding down the edge a little (along the inside edge the door - around the handle/lock.)
But soon realized that the whole thing needs planing back - I think.
Now - because there is a latch set into the door - I'm thinking I need to take it off and plane (sand) down the other side a few mm (where the hinges are attached) and then set/chisel out the hinges again to make them fit.
But I'm wondering if there might be a better/easier way.
Attaching some pix below.
Thanks in advance for any advice.
(apart from get a better builder)
Cheers
Cheers
- PXL_20220223_123400600.jpg (218.09 KiB) Viewed 1434 times
- PXL_20220223_123419310.jpg (110.5 KiB) Viewed 1434 times
- PXL_20220223_123412513.jpg (141.77 KiB) Viewed 1434 times
- Has thanked: 807 times
- Been thanked: 3498 times
What a pain, I do not know of a way to get around a door demount and plane to fit. As a guide, I usually use a pound coin thickness all way around.
- Has thanked: 86 times
- Been thanked: 116 times
You will have to reduce the hinge side. Determine how much you need to take off. Say it's 3mm, cut out the hinge recess first by 3 mm then trim the door edge by 3 mm. I don't know how competent you are at this sort of thing or what gear you have to do it. I use my track saw to fit and refit doors and a 1/4 inch router to cut out recesses for hinges etc. It's very easy to ruin a door with a plane if you aren't accustomed to using one. If that's the case with you I would recommend that you pay someone who is.
- Has thanked: 160 times
- Been thanked: 67 times
Looks to me like a leading edge would sort it bit hard to tell from pics. You've either got to strip the hinge or latch side depending on best way to sort
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2335 times
are the hinges tight with proper sized screws that sit flush with the hinge surface
I thought so. Just wondered if someone had a little/hint for an easy fix I was not thinking of. Thanks.dewaltdisney wrote: ↑Wed Feb 23, 2022 2:52 pm What a pain, I do not know of a way to get around a door demount and plane to fit. As a guide, I usually use a pound coin thickness all way around.
I thought so. I'm OK with a hand plane/chisel. (Always wanted a track saw but don't do enough to justify shelling out the ££££). Thanks.stevei wrote: ↑Wed Feb 23, 2022 4:17 pm You will have to reduce the hinge side. Determine how much you need to take off. Say it's 3mm, cut out the hinge recess first by 3 mm then trim the door edge by 3 mm. I don't know how competent you are at this sort of thing or what gear you have to do it. I use my track saw to fit and refit doors and a 1/4 inch router to cut out recesses for hinges etc. It's very easy to ruin a door with a plane if you aren't accustomed to using one. If that's the case with you I would recommend that you pay someone who is.
I Thanks for replying but I'm not sure what you mean by 'Looks to me like a leading edge would sort it'. I think I will trim back the hinge side.
Yes. all tight and flush fitted. I think they simply did not leave enough clearance when they hung it in the first place to allow for possible (Expected?!) settling.
- Argyll
- Has thanked: 1180 times
- Been thanked: 576 times
Aye Steve's spot on. Hinge side and track saw. a 20-minute job.stevei wrote: ↑Wed Feb 23, 2022 4:17 pm You will have to reduce the hinge side. Determine how much you need to take off. Say it's 3mm, cut out the hinge recess first by 3 mm then trim the door edge by 3 mm. I don't know how competent you are at this sort of thing or what gear you have to do it. I use my track saw to fit and refit doors and a 1/4 inch router to cut out recesses for hinges etc. It's very easy to ruin a door with a plane if you aren't accustomed to using one. If that's the case with you I would recommend that you pay someone who is.
With no track saw..... I'm going to chisel out the hinges on the door a couple of mm and see if it fits - and closes. And iff not hand plane down the hinge side. fingers crossed my rusty chiseling/planing skills will not let me down. Thanks (to all of you).Argyll wrote: ↑Fri Feb 25, 2022 11:03 amAye Steve's spot on. Hinge side and track saw. a 20-minute job.stevei wrote: ↑Wed Feb 23, 2022 4:17 pm You will have to reduce the hinge side. Determine how much you need to take off. Say it's 3mm, cut out the hinge recess first by 3 mm then trim the door edge by 3 mm. I don't know how competent you are at this sort of thing or what gear you have to do it. I use my track saw to fit and refit doors and a 1/4 inch router to cut out recesses for hinges etc. It's very easy to ruin a door with a plane if you aren't accustomed to using one. If that's the case with you I would recommend that you pay someone who is.
- Argyll
That won't work. The hinge side of the door will still be the same size. You need to plane down the hinge side first. I'd just get someone in to do it. Might only cost you £20 if someones passing by.OldSkodaDriver wrote: ↑Fri Feb 25, 2022 11:29 amWith no track saw..... I'm going to chisel out the hinges on the door a couple of mm and see if it fits - and closes. And iff not hand plane down the hinge side. fingers crossed my rusty chiseling/planing skills will not let me down. Thanks (to all of you).Argyll wrote: ↑Fri Feb 25, 2022 11:03 amAye Steve's spot on. Hinge side and track saw. a 20-minute job.stevei wrote: ↑Wed Feb 23, 2022 4:17 pm You will have to reduce the hinge side. Determine how much you need to take off. Say it's 3mm, cut out the hinge recess first by 3 mm then trim the door edge by 3 mm. I don't know how competent you are at this sort of thing or what gear you have to do it. I use my track saw to fit and refit doors and a 1/4 inch router to cut out recesses for hinges etc. It's very easy to ruin a door with a plane if you aren't accustomed to using one. If that's the case with you I would recommend that you pay someone who is.
Thanks for your input but - I wish I had competent tradespeople passing by my house who would only charge me £20 to re-hang a door. Are you sure your not using your time machine and posting from the 1970s Argyll?!Argyll wrote: ↑Fri Feb 25, 2022 12:26 pmThat won't work. The hinge side of the door will still be the same size. You need to plane down the hinge side first. I'd just get someone in to do it. Might only cost you £20 if someones passing by.OldSkodaDriver wrote: ↑Fri Feb 25, 2022 11:29 amWith no track saw..... I'm going to chisel out the hinges on the door a couple of mm and see if it fits - and closes. And if not hand plane down the hinge side. fingers crossed my rusty chiseling/planing skills will not let me down. Thanks (to all of you).Argyll wrote: ↑Fri Feb 25, 2022 11:03 amAye Steve's spot on. Hinge side and track saw. a 20-minute job.stevei wrote: ↑Wed Feb 23, 2022 4:17 pm You will have to reduce the hinge side. Determine how much you need to take off. Say it's 3mm, cut out the hinge recess first by 3 mm then trim the door edge by 3 mm. I don't know how competent you are at this sort of thing or what gear you have to do it. I use my track saw to fit and refit doors and a 1/4 inch router to cut out recesses for hinges etc. It's very easy to ruin a door with a plane if you aren't accustomed to using one. If that's the case with you I would recommend that you pay someone who is.
Well - I did it!
Just in case anybody is going to read this in future:
I took the door off and carefully chiseled the hinges 2-3mm deeper into the door.
Luckily there was large enough a gap on the hinge side of the door that this did not cause any binding and the door closes perfectly.
I'll attach a couple of pix.
(bad focus on the hinge pic - but I think you can see it is now recessed into the door)
Thanks to everybody for your input and advice.
- PXL_20220225_152941912.jpg (227.36 KiB) Viewed 1378 times
- PXL_20220225_152935340.jpg (283.9 KiB) Viewed 1378 times
- PXL_20220225_122220098.jpg (137.36 KiB) Viewed 1378 times
- Argyll
It's all I would charge if I was passing. A lady a few months ago in Cumbernauld wanted the same thing. I told her I'd be passing her in the next week or so. It took me 20 mins. I would have charged more if it were just that job I was travelling to.
I'm not here to rip anyone off.
Glad you got it sorted anyway.
