Maintenance on a spiral staircase
Vwalker
Post by Vwalker »
Hi hoping someone can help, I need to get some new whatever the attached is in my photo. I’ve tried dowels and wooded plugs but not having much luck. Can someone kindly point me in the right direction please?
Thanks in advance :-)
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Google for wooden bobbins and cut one end off
:welcomeuhm:
Has thanked: 734 times
Been thanked: 2335 times
are they structural or cosmetic
inner diameter woud help scale
look like beech by the way
Grendel
Has thanked: 201 times
Been thanked: 499 times
Post by Grendel »
Another option would be to ask on facebook for a local turner who would knock them up for you. Be interesting to know exactly what they do. Concur with BA looks like beech.
Vwalker
Post by Vwalker »
They are structural, they fit in the back hole of the tread and go up into the banister to provide support to the step. Based on the them having to fit tightly I’ll probably try the wood turner route
Grendel
Post by Grendel »
If you can could you post a picture of one in place please? I'm not quite understanding how they work...
if you go the turned route avoid them using soft woods like spruce or pine as they need to use a wood that won't crush under load
and iff the plugs/pegs are tapered make sure this is replicated
i could also be miles out but it looks like perhaps through cast iron into the tread, hence the mild brown discolouration near the head :dunno:
Vwalker
Post by Vwalker »
This is a picture of the peg in situ - thanks everyone for your help so far, I thought this would be an easy thing to sort!
Has thanked: 807 times
Been thanked: 3498 times
Can you not just glue them back in? A friction hold is hardly doing anything and I guess these are just cosmetic unless they have to be removable for access to the fitting beneath?
