Best way to hide exposed wires in electric heater
- ugoleaf
- Has thanked: 120 times
- Been thanked: 4 times
Hello,
Guess I could use isolation tape to cover exposed wires but the cord would still wiggle.
I am wondering if I can isolate exposed wires without opening appliance so that cord would not wiggle.
- fotor_1642341547042.jpg (125.6 KiB) Viewed 1811 times
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
You need to unplug the appliance, remove the tape already there, dismantle the casing, loosen the internal cable clamp and remake the connections inside by shortening the cable. That is the correct way to repair it and it won't take long to do.
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2575 times
arco_iris is correct, the insulation has broken because of movement over time, "covering it up" with tape will not solve anything, it will just hide the problem. If you leave it then the wearing out will continue and the wires will short out and there will be a loud bang.
- ugoleaf
Why is shortening cable necessary? What if I just wrap a new tape around 3 exposed cords?
- Someone-Else
You only shorten the cable by a few inches, enough to pull it inside the heater so the cord grip can do it's job.
As the heater has been moved around over time (no problem) the cable sheath gets stressed and wears out and breaks (Just like it has done) The inner cores need support which can not be given by wrapping tape around it. (No matter how much tape is used) What then happens is the cores rub against each other (They can't if they are in their sheath) the cores can then short out which means the heater can become live, or there will be a fire or there will be a bang.
All because the correct action was not taken.
Would you put a bit of tape on a tyre puncture and expect it to last, of course not, you would get the job done properly. Or wonder why your car is driving funny
As with the tyre scenario, its easy to fix, doesn't take long and will last for quite some time, unlike a bit of tape.
- ugoleaf (Wed Mar 16, 2022 11:06 am)
- ugoleaf
Someone-Else, Hello. The sheath won't budge forward. I wanted to pull it forward to expose more of it so I could put on isolation tape.
- 20220319_081328.jpg (117.77 KiB) Viewed 1706 times
- arco_iris
That is not what Someone-else and I expected to see!
Please post an image of the other side of that grey block, the back of it, opposite where the mains cable goes in, so we can see what it does and how the wires come out of it.
- Has thanked: 117 times
- Been thanked: 214 times
Adding insulation tape is NOT an acceptable improvement
- arco_iris
Ah, so the grey block *IS* the cable strain relief and was moulded like that at the factory - so nothing you can do with it.
Are you able to get to, and remake, where the three wires meet the heater itself?
In this case, cut the cable where it has deteriorated.
Carefully strip back the black cable outer to give you enough length to remake the connections.
Draw the cable through the casing that you have removed, and tie a knot in it so that it cannot pull back through.
Remake the connections, as they are highly unlikely to be screw terminals, you will need crimp terminals - either the correct size blade type where the wires meet the control switch, or use in-line connectors to join the existing internal wires you have just cut to your freshly prepared supply cable. (DO NOT TWIST BARE ENDS TOGETHER AND WRAP IN YOUR INSULATING TAPE! - use proper connectors.)
It would be extremely helpful, though not imperative, to insert a grommet in the casing hole (to the right of the screw shown in the first pictures) to prevent the damage happening again.
The screw & grey block are no longer required, the supply cable will be a bit shorter than before.
- ugoleaf
To get to the part where 3 wires meet the heater I will need to disassemble entire header's casing and see where wires connect there:
- arco_iris
In that case, cut those three wires in the last picture where the black outer meets them (close to the grey block) and use in-line connectors.
These connections are not going to come under any future strain, once you have tied a knot in the main cable to prevent it pulling out of the hole in the casing. Plenty of room in that compartment for this.
