Masking up
Argyll
Has thanked: 1194 times
Been thanked: 584 times
Masking up
Post by Argyll »
I have a pretty big decorating job next week. The walls and ceilings are all being painted white and the skirting white gloss. The carpets are still down so I wondered the best way to mask up. I'll use dustsheets for the floors. I've seen on a few YouTube channels these self-adhesive masking rolls and wonder if they're worth it? I normally just use cheap lining paper with masking tape.
As you know masking up is quite a tedious task so any tips to make my life easier?
Has thanked: 833 times
Been thanked: 3636 times
Masking up
Firstly, I run around the skirting with the wider masking tape, tucking it well in, I use a bolster chisel. I usually buy those thin plastic rooms-sized sheets for a couple of quid and then put dust sheets over them as the plastic tends to ruck and tear. That stick-on cover is good for stairs but you have to be careful on wool carpets for some reason? Good masking is seldom a wasted chore.
Argyll (Tue Mar 15, 2022 12:54 pm)
OnlineOnline
Argyll
Masking up
Post by Argyll »
I should have mentioned I'm using my sprayer.
Nos
Has thanked: 3 times
Been thanked: 80 times
Masking up
Post by Nos »
Iam not a pro but did have to paint the whole house by myself ::b ::b so a few changes of colour on joining walls, I used "Frog Tape" its green and I was impressed with it no bleed through, didn't pull off the new paint, just another idea for you :dunno: A bit Ironic as we live in France. :roll:
ahfix
Has thanked: 61 times
Been thanked: 184 times
Masking up
Post by ahfix »
I'd be inclined to use a stick down carpet roll around the perimeter of the room: https://www.screwfix.com/p/no-nonsense- ... 00mm/72304 overlaid with dust sheets.
I used this stuff when I was taking down the ceilings in my hall, it sticks pretty well and will stay down for days. It does come up at the edges where it gets caught and looses it stickiness.
These users thanked the author ahfix for the post:
Argyll (Sat Mar 19, 2022 11:21 am)
wine~o
Has thanked: 1415 times
Been thanked: 4031 times
Masking up
Post by wine~o »
Just be aware that the sticky stuff on a roll isn't suitable for natural (wool) carpets.
Argyll
Masking up
Post by Argyll »
ahfix wrote: Wed Mar 16, 2022 8:23 am I'd be inclined to use a stick down carpet roll around the perimeter of the room
Good idea. I bought two rolls of the 10m ones in TS as it's better value. I ordered a 25m roll from Amazon for £10.95. The Amazon one wouldn't get here in time but I'll try it later to see what it's like. If it's any good I'll order the 100m roll at £32
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
