dish washer problem
Posted: Sat Mar 19, 2022 12:41 am
by PETER R
hi guys got an old ish whirlpool dishwasher but it wont start ,press the start button and the green light just flashes and makes a pulsing noise ,ive cleaned the filter ,tried switching off and on but it remains the same ,any help appreciated before it gets binned
dish washer problem
Posted: Sat Mar 19, 2022 2:42 am
by Someone-Else
If it is old, bin it, if it isn't old, try White goods forum
Click here to go there.
(White goods have evolved and need more than an electrician.)
dish washer problem
Posted: Sat Mar 19, 2022 3:58 am
by arco_iris
Just a thought, count how many times the green light flashes, then google "whirlpool (model number) dishwasher F(number of flashes) fault code"?
dish washer problem
Posted: Sat Mar 19, 2022 8:06 am
by ericmark
My old dish washer if there was a leak you would see a pool of water on the floor, the new one has a sealed base a well and sensor and any leak switches off dish washer until the until well emptied. It seems had I pulled out dish washer and tipped it on it's side it would have run again.
With features like this only some one working on them will now what yours has,
arco_iris wrote: ↑Sat Mar 19, 2022 3:58 am
Really good idea.
dish washer problem
Posted: Sat Mar 19, 2022 8:48 am
by PETER R
ok thanks I did have a look on youtube ,and the flashes are constant once ive turned it on ,and as there are only two knobs on the front one to stsrt the other settings ,its not digital and the green light ,you can hear the pump working on each pulse,it is emptying ,so thought id ask on here before binning ,as said its old so no point spending to get an engineer out ,may as well just go get a new one
