Ceiling Fan Wiring
TorFey
Has thanked: 1 time
Ceiling Fan Wiring
Post by TorFey »
Morning All;
I want to replace a Manrose gold VMG100T ceiling fan that has failed in my bathroom. when I remove the cover, the wiring colour coming in to the fan is Blue, Yellow and Red. I want to fit an inline fan that has Live, switched live and neutral, but I am unsure which of these wires is which, can anyone help please?
Cheers
Tor Fey
Has thanked: 47 times
Been thanked: 2575 times
Ceiling Fan Wiring
With UK lighting believe it or not there is no specific wiring colours, it is up to the person installing it what colours they use for what.
If you look at a ceiling rose you will often find that one of the blacks is Live, yes it should have a red marker but often they don't, so the black is Live.
You do have the answer to your question in front of you, but as I am not there, it is hard to see. One of your pictures shows the fan label markings (L N S/L) move the label next to your incoming wires and there is your answer.
TorFey (Thu Mar 24, 2022 10:06 am)
TorFey
Has thanked: 1 time
Ceiling Fan Wiring
Post by TorFey »
Thanks as lot for your quick reply, so in theory, this could be the correct way to wire it?
TorFey
Has thanked: 1 time
Ceiling Fan Wiring
Post by TorFey »
So I have download the manufactures diagram and it suggests as above, please can someone confirm this?
Kind Regards
Tor Fey
Scotty001
Has thanked: 26 times
Been thanked: 174 times
Ceiling Fan Wiring
Post by Scotty001 »
If your wiring is set up / Configured as red is permanently live, yellow is switched live & blue is neutral then yes, if your wiring is not configured this way then no.
Return to “Electric Forum UK”
