How can these antique metal handles be mended?
I bought these metal handles on ebay for a cupboard I've been restoring. They were sold as iron but they're not magnetic. I cleaned one a bit and the dangle appears to be brass but I'm not sure about the red bean-shaped bit at the top. My issue is, the loop on all 3 is cracked. Someone suggested using Milliput to fix this. Do you think that's a good idea? Would it hold? (I intend to paint the handles). Secondly, the screw thread, though in great condition, is a measely 13mm & my cupboard is 28mm thick, so a new thread would need to be nearer 35mm. How could a new thread be attached? Many thanks
- h1.jpg (85.86 KiB) Viewed 2707 times
- Has thanked: 823 times
- Been thanked: 3557 times
It looks like all cast brass that has the basket and bead hand painted. Any repair will show though and the metal epoxy paste will work if you can colour it to blend. Brazing would be best but you need to keep cost in perspective.
- Has thanked: 7 times
- Been thanked: 27 times
What thread is it? You could try a thread insert in the door but is it worth the hassle?
Probably better sourcing new handles.
- These users thanked the author banjerbill for the post:
- bourbon (Tue Apr 19, 2022 9:35 pm)
I'm not about giving up, I'm about finding creative solutions to make things work banjerbill. A thread insert in the door sounds like a brilliant idea! Thanks for that.
You get a bit of threaded bar and weld a length on, to give you the length and a metric thread for the nut. The weld does not have to be pretty.
Also, on reflection, the additional threaded bar will need to be a narrower section than the exisiting as there appears to be no shoulder on the through piece. The swing link loops would need to have been brazed at some point for assembly and that is where they have parted through constant wear in use.
- Location: Worcestershire/Warwickshire/Gloucestershire (ish)
- Has thanked: 51 times
- Been thanked: 152 times
Personally, I'd never look at 'heat' to deal with that sort of metal. I think it would just collaspe.
For the repair, consider, RS Stock No.:
204-8356
Rocol METAL REPAIR Compound Epoxy Putty
I've got some, but haven't yet used it. The Instruction Sheet is worth reading.
As regards the thread, as mentioned, it doesn't have a shoulder. It looks to me like 1/4" Whitworth. Perhaps possibly 5/16".
https://www.britishmetrics.com/images/p ... wstd_1.htm
One way would be to counter-bore the material and add a nut. However, not really viable without a limiting shoulder,
Another way would be to epoxy into the material an Imperial Helicoil [of the appropriate thread]. Helicoils are typically supplied as X1. Meaning that the length is equal to the diameter. 1.5 and 2 are available but have to be specified.
Typical suppliers are Cromwell Tools or I use NES
https://nenutsboltsfasteners.co.uk/
Having epoxied in the Helicoil you'd then need an appropriate [Threading] Tap to remove any excess.
Attractive as the handles may seem, is it worth the cost/hassle and for how long would they remain useable?
204-8356
