Outdoor tiling
jackflashh
Outdoor tiling
Post by jackflashh »
I plan on tiling my outdoor veranda next month, and thought I'd post this in case I'm about to do it wrong, or maybe someone can suggest a better way, or tips or improvements.
It is covered by the roof, but still gets rain on it regularly with the wind. From markings on it I can see it has had tiles before at some time.
It is mostly rectangular concrete slab, with a small diagonal section, and measures 1.2m wide x 5m long x 150mm thick. It has a 10-15mm drop to the 1.2m section for rain run off. Other than that it is fairly even and level, and is well above the damp proof membrane.
I have bought enough tiles to do the job, these are a mid gray 150mm square porcelain quarry type tiles. There are single rounded edge tiles for the outer edge, and normal tiles for all the other sections.
I plan to seal the concrete bed in case it proves to be too absorbent. I guess this will slow down the drying time of the tiles, but I will be in no hurry and can leave it for a few days. I plan to use Prime Bond Water Based SBR Primer
I then plan to start on the outside edge with the rounded edge tiles as my datum line to work from, then work inwards, and trim the final row of tiles as I reach the inner wall. I was thinking of a 6mm adhesive bed, with an 8mm gap between tiles. I plan to use Mapei Keraquick Grey Fast Setting Adhesive
Will 8mm joints be enough over 5m, or will I need an expansion joint?
Once the tiles are set I plan to use Mapei Ultracolor Plus Cement Grey Wall & Floor Grout for grouting. I wasn't planning on sealing the area beyond this unless it was advisable.
Any help would be appreciated.
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Outdoor tiling
Post by arco_iris »
jackflashh wrote: Fri May 06, 2022 4:29 pm
You seem to have thought it all out, EXCEPT you're talking about filling these joints with grout, when you should be using a flexible cushion.
Different types are available, google for "tile expansion joint" and/or "tile movement joint", read what links say and look at Images. Tile shops will have them, one every 5m will be enough. As they are 2.4m long, you only need one and cut it in half.
https://www.toppstiles.co.uk/search/Movement%20joint
Return to “Tiling Forum”
