door 597mm wide?
simbob
door 597mm wide?
Post by simbob »
I'm fitting a1000mm base unit as a straight corner unit as per the instructions in the box (B&Q, Caraway, no expense spared or even gone to).
The configuration for the blanking panel and corner post mean that the door width will be 597mm
B&Q do not make a door at that width. Their official advice was yes, we don't make doors of that width, so ask the store staff for advice ( :huray: )
Replacement door suppliers seem to be working with 18mm boards whereas these units are designed with 16mm doors.
I don't think my router skills are advnaced enough to remove 3mm from a standard 600mm door without a wobble. Just curious to know how others would approach this.
Has thanked: 823 times
Been thanked: 3556 times
door 597mm wide?
Can you give us a photo please? Often the best way to get suggestions.
stevei
Has thanked: 87 times
Been thanked: 123 times
door 597mm wide?
Post by stevei »
Unit doors are never the same width as the cabinets. They are always smaller, 595mm to 597mm for a 600 gap. You should be able to lose or gain a small amount on a corner to accomodate the door if needed.
Return to “Kitchen Fitting”
