Mitre saw recommendation
hiace_drifter
Has thanked: 29 times
Been thanked: 16 times
Post by hiace_drifter »
I'd like to buy an electric mitre saw, to be used to cut lengths of wood to length, possibly for skirting and architrave. Is this the right tool? Would one of these do the job:
https://www.screwfix.com/p/evolution-r2 ... 240v/2965v
Any other considerations/recommendations? I do have a circular saw (inherited) for cutting boards, but never used. Thanks.
Has thanked: 48 times
Been thanked: 2605 times
Have you got something to mount it on?
hiace_drifter
Someone-Else wrote: Sat Jun 11, 2022 10:03 am Have you got something to mount it on?
I was going to get a stand to go with it.
Has thanked: 831 times
Been thanked: 3630 times
Just a point here. It ways 11kg plus and you have said in the past that you are not a big bloke so you may find hefting it around a bit hard. I have a small chop saw that does 90% of cuts, it depends on whether the intended jobs you want to do have are for wider boards as chop saws do up to 4" width crosscut and mitres .
Has thanked: 740 times
Been thanked: 2355 times
also best get a aluminium saw stand as a cheaper steel one can easily be more than double the saw weight
hiace_drifter
dewaltdisney wrote: Sat Jun 11, 2022 11:01 am Just a point here. It ways 11kg plus and you have said in the past that you are not a big bloke so you may find hefting it around a bit hard. I have a small chop saw that does 90% of cuts, it depends on whether the intended jobs you want to do have are for wider boards as chop saws do up to 4" width crosscut and mitres .
Good point but it'll only ever get moved from garage to garden to house, and will probably stay in garage 90% of the time.
Maybe I'm stronger than I think... Cement bags are no bother, and I've just demolished a garage/base by hand and moved the rubble round the front of the house.
oz0707
Has thanked: 180 times
Been thanked: 69 times
Post by oz0707 »
I've just sold a dw708 from my garage. Last time I used it was 2018. It weighs an absolute tonne. Don't underestimate how much of a pain in the backside a heavy tool is.
hiace_drifter
Cheers, I will bear it in mind.
TylerKotar
Been thanked: 1 time
Post by TylerKotar »
Have you looked into the Makita's new 40v line? I just picked up their 40v miter saw and am loving it, it has great rip capacity but is still portable and honestly feels more powerful than my older non cordless dewalt.
etaf
Has thanked: 38 times
Been thanked: 154 times
Post by etaf »
whats the maximum size of material you will want to cut ?
As DWD asked
Screwfix often have special versions of the model , so looking at the manufacturers site specification may not always be the same item - so not sure what the max cut for mitre is , as it may not be the same spec as the
Evolution R210SMS+ 210mm Sliding Compound Mitre Saw With TCT Multi-Material Cutting Blade
Code: 048-0001A
shown on the evolution site https://shop.evolutionpowertools.com/co ... ifications
also you may want to factor in a blade with more teeth for finer cuts
210mm dia blade with a 25.4mm bore size
Saxtonblades do do 25.4 blades , and also include reduction rings , if not
So you may want 40/60Tooth blade for finer cuts
Simple DIYer
Wayne
hiace_drifter
The job I want to do first is cutting eight 75mm fence posts to length, plus about 32 lengths of decking. I'm actually happy to do it by hand if there some way to keep my saw straight!
etaf
Post by etaf »
the max cut on that mitre saw states 65mm - so that would mean to cut the 75mm you may need to make a pass and then turn the material over and cut again
BUT the size of material will depend on how far up the blade is lifted and allows space between the edge of the blade and the base
You may need to go and see if its on display at something like B&Q and measure the distance - between the lowest part of the blade and the base - allow for a bit of free space for safety
I have NEVER done this myself , BUT i have read others mentioned and I have been corrected in one case, on posts with the same sort of question, in other website DIY forums
Whats the width of the decking ?
again the max width cut would be 230mm - i think most Decking board would be OK, to cut to length as for example Width at B&Q seems to be 144mm
Simple DIYer
Wayne
hiace_drifter
etaf wrote: Mon Jun 27, 2022 9:35 am
Yeah the decking is 144mm (or very close to that)
It seems the more you pay the greater the max cut height, which I assume is due to bigger blades (and a corresponding bigger gap between blade and base). I think I'll cut the fence posts by hand, as it seems silly to pay more for a bigger mitre saw for a job that will happen very infrequently.
etaf
Post by etaf »
yep, various blade sizes , like 210 diameter v 250mm diameter v 305mm diameter blades
of course other factors come into play.
As a DIYer , i have only used the mitre saw i have for heights that fit the max depth, never tried 2 passes on it , to be honest never even thought of that as an option, until pointed out on a forum very recently , so no experience of that process
Fence posts 75mm & 100mm , i have cut with a circular saw 165mm blade and hand saw - i think i have only ever cut 4 or 5 down, i know i had to cut 1x 75mm and 1x 100mm recently in the current house, before i had the mitre saw
Simple DIYer
Wayne
Return to “Tool Talk”
