Leaning Staircase
Leaning Staircase
Hello all. I have a timber staircase that leans away from the wall. A structural engineer says it's not a big issue, it's just sitting on a joist, all of which lean in because of the age of the property. It looks like a post has been removed from underneath. Is there anything I can do to fix it, at least visually? There isn't any movement when walking up.
- IMG_0722.jpeg (398.34 KiB) Viewed 495 times
- IMG_0721.jpeg (287.74 KiB) Viewed 495 times
- IMG_9842.jpeg (111.6 KiB) Viewed 495 times
- IMG_0540 2.jpeg (119.07 KiB) Viewed 495 times
- IMG_0535 2.jpeg (166.28 KiB) Viewed 495 times
- big-all
- Pro Carpenter
- Has thanked: 735 times
- Been thanked: 2339 times
Leaning Staircase
i would just live with it
it has relaxed and everything flows if you level up the stairs you then have to sort the upper landing and the ground floor level
