- wine~o
- Has thanked: 1414 times
- Been thanked: 4017 times
That wasn't a joiner...
That was Zorro...
That was Zorro...
- big-all
- Pro Carpenter
- Has thanked: 735 times
- Been thanked: 2339 times
it looks like the gate is the wrong size and trellis has been used to pad out to the posts then the gate bodged on to the trellis
- Argyll
- Has thanked: 1180 times
- Been thanked: 579 times
The diagonal support is round the wrong way
- These users thanked the author Argyll for the post (total 2):
- camallison (Thu Jul 28, 2022 10:07 am) • hannes15 (Mon May 01, 2023 10:02 pm)
- Rating: 14.29%
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2571 times
I am not a chippy, what is wrong with the diagonal support being the wrong way round? and what is the wrong way round? (are you saying the top should be on the left, not the right as it is now?)
- Has thanked: 814 times
- Been thanked: 3508 times
The diagonal brace should be on the bottom right side so that it prevents the gate from dropping. The hinge gives the support and the load pushes down onto that fixed point. The whole thing is a bodge, gates need hanging and slam posts, this will drop fairly quickly or the gate use will pull the trellis out.
- Argyll
If you imagine holding out your arm as if you were showing your biceps. You could support quite a lot of weight but if you pivot your forearm away from your body then the further it moves out the less you could support in weight. A gate support works in the same principle. I hope this makes sense?Someone-Else wrote: ↑Thu Jul 28, 2022 10:38 amI am not a chippy, what is wrong with the diagonal support being the wrong way round? and what is the wrong way round? (are you saying the top should be on the left, not the right as it is now?)
- big-all
- Pro Carpenter
i did notice the lanogaid was the wrong way round but as its a light gate square gate a problem in about 5 years time
i also notice the gap under the gate is far too small and the hinges are far to small but though they where too obvious
- Has thanked: 201 times
- Been thanked: 503 times
The brace might not be such an issue if the gate is constructed with tight mortice and tenon joints , it is quite light weight looking although I would personally have put the brace the other way round and probably added at least another pale to close up the gaps a bit as to me it looks too open.
I replaced a gate for a customer not long ago. The original was a ledged and braced affair with a rounded top. Customer was quite adamant that she didn't want the "diagonals" so I had to deepen the ledges as much as possible , glue and fix. I did point out that it may drop over time but she was seemingly unconcerned.
Lanogaid, not a term I've heard before.
