Dyson - DeWalt battery converter
- Argyll
- Has thanked: 1180 times
- Been thanked: 576 times
Not a tool per se but what a brilliant bit of kit.
The battery life on my 5yr old V6 was beginning to drop after a minute on boost (used to be 6 mins) I looked at a replacement battery but I think the Ah is quite low. Then I noticed a DeWalt converter kit for the same price so bought it. You remove two screws and change it over. It's really easy. I've been using it for a couple of days now and seems really good. The original battery only lasted 6 mins on boost so when it ran out I had to wait for the battery to cool and then charge it which took a couple of hours. Now I just whip the battery off and replace it. The only downside is it now doesn't fit on my wall holder but that's no big concern.
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
I had a dyson once. It sucked.
- Argyll
- Has thanked: 160 times
- Been thanked: 67 times
Good idea that is seems to be the first point of failure on all those Dyson hooversArgyll wrote: ↑Wed Aug 24, 2022 9:48 am Not a tool per se but what a brilliant bit of kit.
- Has thanked: 10 times
- Been thanked: 194 times
Dyson are a triumph of marketing over substance , frankly useless
Against my better judgement we bought a battery one about three years ago , had new cyclones and batteries under warranty no improvement and battery life is crap and the inability to change batteries as they charge is poor design , as are the chargers which take an age , lucky power tool manufacturers don’t provide this sort of rubbish
- Argyll
Which is why I changed over to using the DeWalt battery converter. I've found the V6 to be excellent to be fair.
I see you can get converters for all sorts of power tool batteries ! So might try the Makita converter so I can use my power tool batteries
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2334 times
just make sure you choose one recommended by someone as they can ruin your batteries by flattening them beyond the point they won't charge again
