Page 1 of 2
Wi-Fi problem
Posted: Fri Oct 21, 2022 9:01 am
by geralds
Hi I have TalkTalk fast fibre and the speed in the room where the router is 75m on my iPad but the reading on my desktop in the next room is only 20m, is there any device I can purchase to increase the speed to my desktop computer, my iPad has the same reading in both rooms.
Could contact TalkTalk I suppose but don’t want to purchase something from them that does not make it better.
Wondering if someone can recommend a good solution?
Wi-Fi problem
Posted: Fri Oct 21, 2022 9:40 am
by aeromech3
No expert, but I don't think this is an internet supplier problem if you are running the likes of Ookla and using the same Server Centre! likely your iPad has a better wifi module than your PC; my PC on Ethernet is the same as it gets on wifi (13 year old build) 74/18Mbps, but my old (19yrs) laptop gets much lower Download on wifi 49/17Mbps in same room, but on Ethernet same, my conclusion my laptop wifi module is inferior .
Wi-Fi problem
Posted: Fri Oct 21, 2022 9:51 am
by dewaltdisney
Have a look at TP link range extenders they use household wiring to link from the router to the PC. About £30 a pair at Argos.
Wi-Fi problem
Posted: Fri Oct 21, 2022 12:47 pm
by Someone-Else
I am with aeromech3 on this. If your iPad shows the same in both rooms it can't be the signal, but must be your desktop, or what is receiving the signal. (Wi-fi dongle?) As its only in the next room can you not run an ethernet cable from your router to your desktop? You only have to plug it in at both ends
Wi-Fi problem
Posted: Fri Oct 21, 2022 1:07 pm
by dewaltdisney
That's what the TP links do it creates an ethernet link direct router to the computer using the house electric wiring system.
Wi-Fi problem
Posted: Fri Oct 21, 2022 2:16 pm
by Someone-Else
The TP link probably does as you say, but if he has a "not so good" wifi receiver in his desktop the TP link would be a waste of time (as proven by his iPad) an ethernet cable would be much better, and cost less £7.50 Argos
click here or £6 ebay (lots of sellers)
Wi-Fi problem
Posted: Fri Oct 21, 2022 2:23 pm
by Neelix
Buy a long cat 5 cable and see how that improves things.
I’m a fan of Dovolo adapters - the handy “cockpit” tool you get allows you to see the speeds between the different extenders. Use the hard wired units too
Wi-Fi problem
Posted: Fri Oct 21, 2022 2:25 pm
by dewaltdisney
You are missing my point SE the connection is ethernet cable into Tp link, down household electrcity wires to next Tp link ethernet cable from Tp to the PC so it emulates a continuous ethernet connection.
Wi-Fi problem
Posted: Fri Oct 21, 2022 3:25 pm
by Someone-Else
Oh, I see.
Let me see if I have this right.
The kit you speak of costs £30 (Argos, no worries there.)
They must be on the same circuit (You would hope not a problem if he is in the next room)
They shouldn't but can suffer mains interference
They are not as fast as an ethernet cable
The kit you mention only has one cable, TWO cables are required, one for each end
A 10 M long ethernet cable can be had for £6
Sorry, I am trying to understand why you would spend £30 more on something that is not as good as a cheaper option, and no emulation what so ever, and you
still need to buy a second ethernet cable
Argos Q & A page wrote: This kit includes a single 2m ethernet cable.
But then its not my money.
Wi-Fi problem
Posted: Fri Oct 21, 2022 4:34 pm
by dewaltdisney
I thought I had two ethernet leads in my pack? I have my PC upstairs and my Sky box in the sitting room all connected using 3 Tp links
Wi-Fi problem
Posted: Fri Oct 21, 2022 8:24 pm
by Harry001
This might just be due to the wifi "card" in your PC. I had the same issue before and got an external USB wifi connector - something like this -
https://www.amazon.co.uk/TP-Link-TL-WN8 ... B0088TKTY2.
It fixed my problem. I suppose it depends if you've got an old desktop.
Wi-Fi problem
Posted: Sat Oct 22, 2022 1:23 pm
by Neelix
Someone-Else wrote: ↑Fri Oct 21, 2022 3:25 pm
This isn’t correct
Wi-Fi problem
Posted: Sat Oct 22, 2022 1:27 pm
by Someone-Else
Neelix wrote: ↑Sat Oct 22, 2022 1:23 pmThis isn’t correct
I figured that, but that is what the "blurb" says
Wi-Fi problem
Posted: Sat Oct 22, 2022 1:43 pm
by Rorschach
WiFi cards in most laptops are poor because the aerial is concelled deep inside usually.
I was getting great speeds on my phone but my laptop right next to it was less than half that. I bought an external WiFi dongle with a large aerial on it specifically marketed for getting better signal. Only cost me about a tenner and now my laptop gets a speed that pretty much matches my phone. Well worth it.
Wi-Fi problem
Posted: Sat Oct 22, 2022 2:36 pm
by Someone-Else
That is true,
Rorschach wrote: ↑Sat Oct 22, 2022 1:43 pmWiFi cards in most laptops are poor because the aerial is concelled deep inside usually.
Sorry to point this out, but the OP said
geralds wrote: ↑Fri Oct 21, 2022 9:01 ambut the reading on my
desktop in the next
