lap tester help please
paul777
Has thanked: 1 time
Been thanked: 1 time
Post by paul777 »
hello i have had had this lap tester for 4 or 5 years all working great but !
just added a spur off a double socket
when i put the lap tester in and switch the socket on all is ok BUT !
when i switch off the socket a red light remains on i cant see why adding a spur would course this to happen so went around the house around 5 sockets i tested this red light remained on but the socket switch was off !
any help please
thank you paul
Neelix
Has thanked: 117 times
Been thanked: 212 times
Post by Neelix »
Those CAN NOT test sockets in any useful way.
ericmark
Has thanked: 116 times
Been thanked: 782 times
Post by ericmark »
I have seen a similar post before, the tester alerts there may be a fault, but it will not really identify the and fault, even the more expensive versions around £50 with loop, pass at around 1.9 ohm, where for a ring final the pass mark is 1.37 ohms, so only any good testing a radial.
You were asked on the other forum is your supply TN or TT, better answer that first rather than re-post on another forum.
Return to “Electric Forum UK”
