Sealant For Tiled Floor
mrsparks
Has thanked: 7 times
Been thanked: 9 times
Post by mrsparks »
I've just had my kitchen/diner re-done, with porcelain floor tiles and mdf skirting boards. I'm looking to apply silicone sealant between the tiles and skirting - mainly to stop moisture from mopping the floor ruining the mdf, but also because the tiles have texture so that gaps around the skirting are uneven. I want to use a decent brand, so I'm pretty much settled on Dow but there's so many different ones - 785, 785+, 791 and more. Could someone please advise which one I should use?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
You don't mention colour preference, I believe 791 is available in multi and the 785+ is mostly where bacteria is a concern?
stevei
Has thanked: 94 times
Been thanked: 128 times
Post by stevei »
mrsparks
Post by mrsparks »
aeromech3 wrote: Wed Dec 14, 2022 4:24 am You don't mention colour preference, I believe 791 is available in multi and the 785+ is mostly where bacteria is a concern?
I'll be doing it in white. Not sure if I need to be concerned about bacteria on a kitchen floor - or maybe I should? Given that, which of those would you go for? Or a different one?
mrsparks
Post by mrsparks »
stevei wrote: Wed Dec 14, 2022 12:45 pm Have a look at this video <span class="skimlinks-unlinked">https://www.youtube.com/watch?v=_DI4hfHM_Hg</span>
I'm actually subscribed to his channel and watched that video some time ago.
Return to “Tiling Forum”
