Noise from Indirect Expansion Unvented Storage Cylinder
iainh
Post by iainh »
Hi all,
Looking for some guidance on noise from an unvented cylinder. Due to the water mains pressure being a bit low we went down this route so I'm not sure what to expect noise wise as it's not a system type I'm familiar with.
Hoping someone can advise if this is a 'normal' amount of noise. I couldn't find the detail on Google and the manufacturers data doesn't appear to cover it.
Video shared here -
VID-20230130-WA0008.mp4
(7.64 MiB) Downloaded 40 times
And photos of spec
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
If that's during cylinder reheat it sounds like coil resonance caused by too much flow going through the heating coil. Sometimes you need to add a lockshield valve across the flow and return before the cylinder to alter the flow rate
