Can press-fit fittings be used on PEX pipe?
Stratf01
Has thanked: 1 time
Post by Stratf01 »
As the subject asks can press fit fittings such as Xpress be used on PEX with a metal insert?
Thank you
Alya Koe
Been thanked: 1 time
Post by Alya Koe »
Yes, press-fit fittings can be used on PEX (cross-linked polyethylene) pipe. In fact, press-fit fittings are a popular option for connecting PEX pipe because they provide a secure, leak-proof connection without the need for special tools or equipment.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
No you shouldn't use Xpress fittings on PEX.
Xpress are M profile and PEX fittings are U profile jaws.
You can press onto push fit but you will never get a manufacturer of either the fitting or the pipe to warranty it so if there's a problem you are on your own and your PLI will run away from any subsequent claims.
MLCP and U profile is looking the way to go nowadays
