Painting Coving With Torn Paper
mrsparks
Has thanked: 7 times
Been thanked: 9 times
Post by mrsparks »
I've had some coving put up - the plasterboard type - and I'm just about to embark on painting it. There are a few tears on the surface paper - nothing major and it's only the top layer of paper that's damaged - but I'm wondering whether I should seal those areas first.
Things I've thought of that I don't need to go and buy are Zinsser 123 or BIN, PVA, or even a very thin coat of filler.
Is it necessary and will any of these do the job?
I'll be painting with Tikkurila Anti Reflex 2 if that matters.
As a bonus question, I've never painted bare plasterboard coving before. Would I be OK just using AR2 straight, or should I dilute a little. Or something else like 123 first?
Has thanked: 823 times
Been thanked: 3560 times
New coving sucks paint quite a bit and I have always put a sealing coat of primer over it to inhibit this. I have used an acrylic primer/undercoat Joncryl, just because I had it to hand but it worked well.
mrsparks
Post by mrsparks »
dewaltdisney wrote: Wed Mar 01, 2023 9:20 am New coving sucks paint quite a bit and I have always put a sealing coat of primer over it to inhibit this. I have used an acrylic primer/undercoat Joncryl, just because I had it to hand but it worked well.
Thanks. Would you worry especially about the torn paper?
I don't suppose Zinsser 123 would do? Or, I have some Bedec Aqua undercoat/primer that I normally use for wood - don't know if it's acrylic.
I also have a newly plastered ceiling to paint. I've read the Anti Reflex datasheet and says to dilute the first coat by 20% - so that's what I'm going to do there.
I would have thought the 123 would do it, It is just sealing the cove surface. Practice in the past was oil undercoat mixed with emulsion.
Tom d'Angler
Has thanked: 1142 times
Been thanked: 553 times
Post by Tom d'Angler »
As DWD says, new coving is very absorbent. I would mist-coat the coving first (use the Anti Reflex 2, watered down 20% water to 80% paint) then have a look to see if the torn bits are noticeable. If they are, a bit of filler will do the trick. Let it dry fully, sand the filler gently, and then two coats of AR2 as normal.
mrsparks
Post by mrsparks »
dewaltdisney wrote: Wed Mar 01, 2023 11:46 am I would have thought the 123 would do it, It is just sealing the cove surface. Practice in the past was oil undercoat mixed with emulsion.
Thanks. I found this article which mentions 123 for priming coving. So that's what I shall use. I love it when I don't need to go out and buy stuff!
mrsparks
Post by mrsparks »
Tom d'Angler wrote: Wed Mar 01, 2023 1:19 pm As DWD says, new coving is very absorbent. I would mist-coat the coving first (use the Anti Reflex 2, watered down 20% water to 80% paint) then have a look to see if the torn bits are noticeable. If they are, a bit of filler will do the trick. Let it dry fully, sand the filler gently, and then two coats of AR2 as normal.
Sorry, I posted my response before I saw your post. Now I'm in a quandary!
Argyll
Has thanked: 1183 times
Been thanked: 581 times
Post by Argyll »
Tom I don't want to hijack the post but is that anti reflex stuff suitable for priming bare plasterboard before lining paper?
Tom d'Angler
Argyll, I don’t know. I would use watered down paste to prime (size) the plasterboard.
Tom d'Angler
Tom d'Angler wrote: Thu Mar 02, 2023 4:34 pm Sorry, I posted my response before I saw your post. Now I'm in a quandary!
Don’t be in a quandary! I’m the past I have used oil-based undercoat to prime new coving. If you’ve got something to hand that will do the job just as well, it would be daft to not use it. :-)
mrsparks
Post by mrsparks »
Tom d'Angler wrote: Thu Mar 02, 2023 4:37 pm
:thumbright:
