Would anyone have a manual for the PCF 250-12 model?
I was running it on the winter setting for quite some time, but with the current electricity cost I noticed that it is heating up the water very often, averaging 1.2kW or almost 900kWh per month.
Changing the setting to summer turns off the heaters. They are not turned on even when the timer is set to heat up the water. All of the fuses are fine.
User manual for Churchill Imstor Electr Central Heating Syst
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 569 times
mizoo, Digging up old threads is frowned apon. I have started you a new thread. Old thread here if needed viewtopic.php?t=68137
