Recomendations please 👨🏼‍🦲
Has thanked: 47 times
Been thanked: 2590 times
I am looking to get a new non smart roomstat, I was wondering if any of you have personal recommendations?
Requirements.
1) Not a smart stat (Too expensive)
2) Mains operated (Had battery ones in the past, they fail too often)
3) Clean contacts (As opposed to switched output)
4) Average size (Less than 12 x 12 cm, most are?)
5) MUST have times / programmes (Call it what you will)
The idea being it changes the max room temp at specific times every day, twice a day would be fine. (So at say, 16:00 it goes from 18 to 21 then at say 23:00 back to 18)
I want one that is easy to set up, and works.
Thanks all.
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
So you want a mains powered room stat.
Do you have a neutral at the location you want to place it?
Yes, I have neutral where the stat is going.
Neelix
Post by Neelix »
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
I have used the Digistat+2, but though they list a mains version I have not come across it; in my home, whilst I am away, it is sitting with the battery stat on kitchen table set to frost which shows an OFF in the window but brings heating on at 7*C because the boiler CH is set to always ON at the LP522 and governed by this Stat.
It can be programmed for vacation but in Winter I prefer this setting.
The 2x AA batts last a long time in the Stat.
Many thanks to both of you. :thumbleft:
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
What boiler is it going on?
Sorry, I don't know.
I can't read its model, I know it's a baxi, I know it's just over 10 years old, but I can't read the name, I even tried taking a picture of it, and you can't see it, let alone read it.
Razor
Post by Razor »
The Drayton linked above is a very old design, not bad but not the best either.
I have fitted dozens and dozens of these https://www.esicontrols.co.uk/product/4 ... hermostat/
They are around £50 and I have never had one fail yet. They are very like an older Honeywell to program and the load compensation feature gives you something known as TPI - basically as the house warms up it brings the boiler on less often and for shorter periods which saves temperature overshoot and wear on the boiler.
Razor
Post by Razor »
BTW that's assuming it's a combi and you don't have a cylinder...
An update.
If anyone is thinking of getting an esicontrols ESRTP4+ programmable room stat you can get them for less than £50 Click me only £35 :-)
It will operate most boilers, but do bear in mind
It is battery powered, which is not what I am looking for
Someone-Else wrote: Fri Mar 10, 2023 3:45 pm Requirements.
It is also "open therm" which reduces gas being used as and when required, its just not the stat for me.
I ended up getting one of these Click me Its mains powered, it is also controllable by an app, which I am not using, and not interested in, and yes, it works well without the app.
