Stone Paint stripper
- Has thanked: 1 time
Hi new here can any decorators on here know how to remove flakey paint from sandstone sills I thought about liquid paint stripper but read it can soak in to stone and cause damage I don't think scraping it will work is there any tool I can use thanx.
- dynamod
- Elephant Man
- Has thanked: 592 times
- Been thanked: 1444 times
The following assumes a water-based masonry paint was originally used
Scraping paint right back to the stone is normally unnecessary, and in any case, it can be surprisingly time-consuming. Best option is to scrape off the obviously flaking paint to a sound edge, fill any dents and cracks with a decent exterior filler (these often don't sand readily, so make sure repairs are flush before the filler sets) Prime bare areas with slightly thinned out masonry paint, then overcoat the cills with full strength masonry paint.
If you have to fight to remove paint, then in reality it has a pretty good grip of the surface underneath, and removal isn't strictly necessary. Hence, the description above. In addition, chemical stripping agents can soak into the stone, and if they're not completely removed, they can react with the new coating. Better to stick to a belt and braces approach.
Nihil expectore in omnibus
- Argyll
- Has thanked: 1183 times
- Been thanked: 581 times
Wire brush and Dettol.......oops sorry that's for something else.
A wire brush normally does the trick or good jetwash.
I'm not a P&D btw but I've been successful with those methods in the past.
