"Reducers" query
- Has thanked: 196 times
- Been thanked: 7 times
"Reducers" query
Hi, Regarding brass 15mm to 10mm radiator valve "reducers" which are best, those that come as a single part or those that come as three parts ? Thank you.
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
"Reducers" query
Not had much experience with either, but understand this:-
Even if you are using copper pipe with the one piece, you need to be careful about the tightening torque (to judge when it starts to crush) and it is a one time fit, make a mistake and it is junk, still need an insert with plastic pipe. The 3 part uses a standard olive which most have experience with tightening, make a mistake and its just a new olive (provided you have enough spare pipe!).
- These users thanked the author aeromech3 for the post:
- rautospoon (Thu Apr 20, 2023 9:54 am)
- toolbox
- Has thanked: 129 times
- Been thanked: 214 times
"Reducers" query
I prefer the three part ones myself.
- These users thanked the author toolbox for the post:
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
"Reducers" query
If you can avoid it don't use them. Either buy 10mm valves or if you can solder then sweat 15/10 reducers on the end of the pipes.
The reducing sets do work ok if used correctly but they will always be the weakest point of the system
- These users thanked the author Razor for the post:
- rautospoon (Thu Apr 20, 2023 8:49 pm)
"Reducers" query
I am and already have a Drayton TRV4 White 15mm 07 07 260 valve and lockshield and am fitting a new larger radiator.
