I have almost “run out” of Rubbol BL Primer (blue label) and Rubbol BL Satura (purple label) both “water based” that I have used for many years and found to be first class.
I understand these (unbelievably !) are no longer produced ? If so, are alternative Sikkens (“water based”) products available ?
If not, what is currently recommended as being the "Rolls Royce" of "water based" satin finish ?
Many thanks.
Sikkens Query
- Has thanked: 196 times
- Been thanked: 7 times
Sikkens Query
Rather surprised not to receive a single reply ? Is the activity on this forum "on the wane" ?
- Tom d'Angler
- Has thanked: 1142 times
- Been thanked: 553 times
Sikkens Query
I didn't comment because I've never used those products.
- These users thanked the author Tom d'Angler for the post:
- rautospoon (Fri May 12, 2023 2:27 pm)
Sikkens Query
"If not, what is currently recommended as being the "Rolls Royce" of "water based" satin finish ?"
- Tom d'Angler
Sikkens Query
I have to be honest and say I rarely use water-based on internal woodwork as I just don’t like the finish (look and feel) or that it usually requires three coats instead of two. Before I start a job, I do explain to my customers why I prefer oil-based and that it will fade over time, and they are still happy for me to use it.
- rautospoon (Fri May 12, 2023 3:10 pm)
