Zinsser BIN - reusing a plastic paint stirer
- Has thanked: 16 times
- Been thanked: 1 time
Daft question.
I mixed a brand new tin of BIN yesterday with a plastic stirring stick.
Some BIN has now dried on this stirring stick.
Do I need to throw this stick in the bin (pardon the pun) or can I reuse it to stir the BIN again?
I'm asking because I'm worried that the dry BIN on the stick will become reactivated, then drop off the stick and put lumps in the tin.
Thanks in advance.
Thanks in advance.
- Has thanked: 201 times
- Been thanked: 509 times
I don't know the actual answer but as it's common to give BIN a second coat I'd assume it's not going to reactivate on the stirrer. You could always give the stirrer a scrape if you are worried , or just chuck it and use another. Personally I use wooden stirrers which are basically a strip of wood with holes in. I give the holes a ream out every so often but that's about it.
- Has thanked: 823 times
- Been thanked: 3560 times
Methylated spirit is the solvent, it will soften the dried BIN to allow you to scrape it clean. If it stays solid it will be fine in the BIN as a stirrer.
- These users thanked the author dewaltdisney for the post (total 2):
- toolbox (Wed May 24, 2023 12:10 pm) • DaveyH (Sat May 27, 2023 9:02 pm)
- Rating: 14.29%
- Tom d'Angler
- Has thanked: 1142 times
- Been thanked: 553 times
Buy a couple of these: https://bit.ly/432qvt7.
I've got them and they are terrific. Easy and quick to use and very easy to wipe all the paint off before it dries. So much better than those plastic stirrers.
- These users thanked the author Tom d'Angler for the post:
- DaveyH (Sat May 27, 2023 9:02 pm)
- Tom d'Angler
Mine haven’t and I use them almost every day, on w-b and o-b. They really are terrific.
- Tom d'Angler
Dunno but Mrs d’A could do with a set for her cauldron...
In the interests of scientific endeavor, I reused the plastic stirrer today.
About 5 minutes after stirring I was able to wipe off the bulk of today's BIN and yesterday’s dried on BIN with a piece of dry rag. So being resubmerged in BIN did reactivate yesterday's dried on BIN. I also didn't experience any lumps in the roughly 150ml I decanted from the tin into my paint kettle (which was an old pot noodle pot).
As I said, Methylated spirit is the solvent and as this is in the BIN the solvent in the paint will soften it up. Have a read of my link in blue below it might help.
- DaveyH (Sat May 27, 2023 9:03 pm)
