Orange spots. Rust. Washing machine or power flush?
e5c3d4
Post by e5c3d4 »
I get orange spots when washing clothes. Please see photo. I think it is rust.
I’ve checked there’s no metal in the machine. I have also run a long wash with lemon juice. Neither have solved it.
I read power flushing is the answer to rust elsewhere in the system.
How can I tell if it’s the washing machine or if I need to to power flush?
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 566 times
Post by moderator2 »
Moved to general diy as not a plumbing problem. SFAIA a powerflush is used on central heating systems to prevent or remove sludge build up in the radiators.
Has thanked: 807 times
Been thanked: 3498 times
Start using Dettol laundry rinse instead of conditioner. The machine will be cleaned in the process as well as the clothes of any bacterial or fungal presence. We have used it for years
Has thanked: 47 times
Been thanked: 2559 times
e5c3d4, moderator2 is not wrong, a "powerflush" is for cleaning your central heating system (Pipes and rads) a washing machine gets water via the water mains, so a powerflush would be no use and a waste of money.
Would you do me a favour (and post the results here)
Washing machine off, drum empty.
1) Spin the drum by hand, what did you hear?
2) Stand infront of machine put one hand in towards the top (Like I am showing here)
Gently pull / lift inner stainless steel drum.
Repeat.
Did it move? (Not the whole thing, just the stainless steel inner drum)
Return to “General DIY forum”
