Stiff bathroom door lock
hiace_drifter
Has thanked: 29 times
Been thanked: 16 times
Post by hiace_drifter »
I fitted a new handle/lock to the bathroom door, like this:
The thumb turn lock worked wonderfully before the handle was installed, but once installed it is too stiff to use. This applies even when door is open (i.e. it is not foulling on the door frame.
I have checked to make sure there is nothing catching where the barrel rotates inside the door ... is it perhaps because the the two backplates of the door handles are not 100% parallel/square with each other and it is causing friction?
wine~o
Has thanked: 1414 times
Been thanked: 4015 times
Post by wine~o »
hiace_drifter wrote: Thu Jul 13, 2023 8:20 am is it perhaps because the the two backplates of the door handles are not 100%
That would certainly cause the symptoms you describe.
hiace_drifter
wine~o wrote: Thu Jul 13, 2023 12:44 pm
Ok, I'll have a play, thanks!
Return to “General DIY forum”
