Replacing External Soil Pipe
- Distorted Vision
- Has thanked: 4 times
- Been thanked: 7 times
The external soil pipe previously had a slight leak a few years ago and was repaired by Homeserve.
The lower half is look unsightly and I wanted to have it replaced. I was wondering approximately how much it will cost. Can they just replace the affected lower sections?
- Has thanked: 818 times
- Been thanked: 3513 times
It is limescale staining and you can remove it with a bit of patience and elbow grease. Spray it with Viakal and leave for 10 minutes and then spray again and scrub it with a nail brush. or similar stiff bristle brush. It might take a few applications but I am sure it will clean up.
- Distorted Vision
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2574 times
It does look like it is leaking from the joint above the boss, as I understand it, you don't want to take it off. Is the bottom part cast iron? and what does it run into?
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Yes the 1 1/2" pipe on the left can be cut and rejoined into a new lower section stack. That will get rid of the leak as well.
Materials wise probably a shade under 50 squids and half a days labour in total by the time they've got everything etc. I'd probably budget £200/£250 depending on your area and a proper site survey.
PS looks like Homeswerve didn't fix it very well....
- Distorted Vision
It's all plastic and goes straight into the ground. My own concern is would they need to remove the surrounding patio flagstones. I paid a lot of money to have the whole patio re-pointed last year. There is a row of Aco drains on the wall so either side of the soil stack going into the ground.
How did the Viakal go? As it is plastic you could resort to painting it with Plastikote but I am sure the Viakal will remove it.
- Distorted Vision
I've not tried yet. Raining everyday apart from yesterday and overseeded the lawns which took all day.
