Summer house door glass advice
- Has thanked: 1 time
Hello. Must have had summer house now five years and use as office every day. All windows glass are fine but noticed the door glass has deteriorated. See pictures. It's as if the glue has worn away from several areas of the glass. Is there some sort of glue/sealant I should use to fill the gaps?
- IMG_20230712_183829.jpg (258.13 KiB) Viewed 314 times
- IMG_20230712_183840.jpg (254.49 KiB) Viewed 314 times
- Has thanked: 807 times
- Been thanked: 3498 times
Cheers for that, so a little bit of timber beading, how would I apply it?
Panel pins (little nails) hammered through, predrilling small pilot holes through the bead helps with nailing but you could silicone them on. However, silicone fixing might make the beads harder to remove if you ever have to change the glass panel, but much easier to do now.
Could I potentially just use glazing silicone sparingly and carefully around the perimeter and leave like that?
It was hard to see in your pictures but on a closer look does it already have plastic beads holding in the glass panel? Usually, the beads are snapped tight against the glass I think I have been talking shite because I could not see properly. Can you take another photo back a bit so I can understand if you need a new gasket this what a gasket looks like https://www.youtube.com/watch?v=htPm8qK0FSg
See below, both glass doors, some where hasn't worn away, others which have.
- IMG_20230715_193238.jpg (244.03 KiB) Viewed 291 times
- IMG_20230715_193246.jpg (285.45 KiB) Viewed 291 times
- IMG_20230715_193253.jpg (285.02 KiB) Viewed 291 times
- IMG_20230715_193304.jpg (270.33 KiB) Viewed 291 times
- IMG_20230715_193312.jpg (339.95 KiB) Viewed 291 times
- IMG_20230715_193321.jpg (249.39 KiB) Viewed 291 times
- IMG_20230715_193339.jpg (314.25 KiB) Viewed 291 times
- IMG_20230715_193343.jpg (246.21 KiB) Viewed 291 times
- IMG_20230715_193347.jpg (319.63 KiB) Viewed 291 times
- IMG_20230715_193354.jpg (360.68 KiB) Viewed 291 times
I suspect that it had silicone before and as it appears exterior facing you want a weather seal so make sure you seal against rain-causing issues. Ensure you get exterior sealant.
- kowalski181 (Sat Jul 15, 2023 8:05 pm)
