My waterbutts came with rather cheap fixtures.
On the back of the tap is a plastic "nut":
It's so far down inside the butt, I have to hold it whilst my wife rotates the tap to tighten.
There is also a pipe connecting two butts, again very low down and this has a flush back so impossible to tighten properly:
All the connectors leak, even the nutted one, which I can get reasonably tight.
Any suggestions for better connectors? Or ways to seal?
Waterbutt connectors
- Has thanked: 29 times
- Been thanked: 16 times
- Has thanked: 26 times
- Been thanked: 173 times
For ways to seal, almost the same as sealing a sink waste, washers / silicone sealent. The good thing with cheap plastic connectors are if needed they are easy to break off and replace / reseal.
With metal ones if they have correded (which they will as are sat in water all the time) then your not cracking that nut off at anytime if you need to replace or re seal.
Good points. I will measure up and get some extra washers. Thanks.Scotty001 wrote: ↑Tue Jul 18, 2023 11:55 am For ways to seal, almost the same as sealing a sink waste, washers / silicone sealent. The good thing with cheap plastic connectors are if needed they are easy to break off and replace / reseal.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Lots of plastic tank connectors on the market now
https://www.screwfix.com/p/flomasta-twi ... lsrc=aw.ds
