There appears to be some sort of gap where my wood burners flue comes out through the roof that is allowing rain water to travel down the exterior of the flue pipe and then drip down the cavity space where the flue goes down to the log burner. This is now causing visible water damage to the flue surround as it enters through the ceiling above the log burner. I am thinking I can just throw some expanding foam into the space between the flue and the surrounding area as it comes out to the roof but obviously am abit lost as to whether this is even a good idea and to what grade of heat resistantance I need. The section I'd be filling is well away from the burner itself but obviously still does feel warm to the touch when the burner is on. It's a standard 2 floor house with the burner being on the ground floor.
I'm a complete novice so any help will be appreciated and apologies if I've missed off some basic information that would be pertinent
Heat resistant expanding foam
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
There should be a weathering slate or flashing kit sealing the pipe where it penetrates the roof. I would be asking the installer how it's sealed.
Don't use foam. It won't solve the problem, it will just make it more difficult to rectify properly.
This is what a weathering slate looks like - It is almost certainly NOT the one you need. Only posting it to give you an idea
https://www.toolstation.com/weathering- ... lsrc=aw.ds
