attaching shop vac to sander
hiace_drifter
Has thanked: 29 times
Been thanked: 16 times
Post by hiace_drifter »
I have one of these ...
Is there a standard adaptor you can buy to connect the dust outlet to a vac?
I have something like this:
https://www.screwfix.com/p/titan-ttb776 ... 240v/665kh
I have googled and found adaptors, but they're on ebay rather than screwfix/toolstation. I would have thought it would be a standard item.
Has thanked: 734 times
Been thanked: 2335 times
yes its called an empty pop bottle or mastic tube cut to perhaps 120-160mm long slot full length and lots off electrical tape to give form with extra winds each end to make a good fit
it will work better the more parallel the tube is this may include tape on machine outlet
you can cut the length down once it works to the minimum needed
you can buy stepped adapters
random link
https://duckduckgo.com/?t=ffab&q=steppe ... 7-1&ia=web
hiace_drifter
big-all wrote: Fri Aug 25, 2023 9:42 am yes its called an empty pop bottle or mastic tube cut to perhaps 120-160mm long slot full length and lots off electrical tape to give form with extra winds each end to make a good fit
random link
<span class="skimlinks-unlinked">https://duckduckgo.com/?t=ffab&q=steppe ... =web</span>
Genius! Thank you, will have a play around.
Has thanked: 47 times
Been thanked: 2559 times
Just saying...................most "plastic bottles" are made really small, heated and air blown into them (while in a mould) Point being if you get it round both ends, then heat it, often they will shrink, giving a tight fit.
Return to “General DIY forum”
