Drill press stand
meddyliol
Has thanked: 9 times
Been thanked: 1 time
Drill press stand
Post by meddyliol »
I need a Drill Press and I need it to be able to drill holes through 10cm thick posts. I have been looking at some and they say that they only drill about 6cm. I am probably over thinking this but am looking at the wolfcraft Drill Stand I 3406000 but am still not sure if it will do the job.
Any advice would be appreciated.
Brian
Has thanked: 807 times
Been thanked: 3498 times
Drill press stand
When drilling do it in stages starting with a small bit to act as an accurate pilot hole. I usually drill a drill guide for the job using a section of wood that I drill accurately on centre. This is clamped (or temporarily screwed) in position and then careful drilling should see an accurate hole. To be fair the deviance in a 4" thickness should be minimal taking care. It is all about accurate measurement and taking your time.
meddyliol
Drill press stand
Post by meddyliol »
Thanks, will order one now.
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Drill press stand
Post by aeromech3 »
The lever feed movement only allows 60mm depth in one cut; you could drill a small pilot hole then continue with a hand drill to reach the other side, then open to full diameter and then reverse wood to drill through from other side using pilot hole guide, a lot of faffing about.
Bob225
Has thanked: 98 times
Been thanked: 872 times
Drill press stand
Post by Bob225 »
Drill the 60mm depth, place a 30-50mm piece of scrap underneath continue drilling the hole - quick and dirty, but it gets the job done
Return to “Tool Talk”
