Wall showing damp from shower area - tell me the worst!
Posted: Wed Sep 06, 2023 3:03 pm
Hi all
I have a feeling anyone replying to this request for advice is going to tell me it's bad news....but I ned to have it confirmed.
I've attached some photo's of a wall showing signs of water leakage from the shower that is on the other side of the wall in the bathroom. It started just a few short months ago but has accelerated the last month or so.
You can see patterns of damp and paint that has started to bubble up. You might be able to notice that the area affected is in the shape of a small doorway, that's because there used to be a door to a storage cupboard and has been filled in when the bathroom was enlarged. I can't tell from hitting it with my knuckles whether the doorway was filled in with brick or plasterboard or something else. It probably doesn't matter as water is getting through from the shower in any case.
The bathroom was refitted 3 years ago with a bath and electric shower removed and a walk-in shower installed and a shower linked to a gas boiler installed. The mixer tap in the shower is roughly in line with the plug socket on the left and up just below the larger picture frame. Curiously that is not where I can see any dampness, so my thinking is that water is seeping into the grouting and/or any cracks in the grouting. The water then follows the grooves of the tile adhesive and spreads outwards in various directions.
Crucially, having done some searching of UH videos on how to install bathrooms, I don't think the shower area was tanked before being tiled. I believe the tiles went straight onto plaster.
So, what's to be done? It looks to me like the shower unit and tiles will on need to come off and...well...I think the shower project needs to start all over again. There's not just the wall that the shower mixer is on but the left hand wall within the shower unit could be affected and all those tiles remove too (the other 2 sides are all glass panels). As you stand in the shower until facing the mixer tap the wall to the left backs onto a bedroom and although I can't see evidence of dampness on that side it is only a matter of time.
I also expect that the affected wall that you see in the photo's will need repairing but I'm not sure what would need to be done though removing existing plaster and re-plastering will be required.
I'd appreciate some advice on best plan of attack on this before it gets worse. I've dabbled in DIY and prepared to have a go at whatever is required though I've not done anything remotely as difficult as this.
Many thanks in advance for any pointers submitted.
Cheers, Ian.
Cheers, Ian.
