Removing very long nail
hiace_drifter
Has thanked: 29 times
Been thanked: 16 times
Post by hiace_drifter »
I'd like to try and remove a very long nail, before I install some upvc boards in my porch. Any tips on how to get a claw hammer/crow bar to grip on to it? Should I just a saw/multi tool to partially cut into it to give a notch for the hammer/crowbar to grip onto? Or just give up and cut through it, and leave a remnant in the wood?
Sorry for terrible photo, will try and add a better pic later!
Has thanked: 47 times
Been thanked: 2564 times
Put a block(s) of timber under your hammer (To raise its height) and continue to pull via its claw
toolbox (Wed Sep 20, 2023 3:42 pm)
Has thanked: 735 times
Been thanked: 2336 times
someone has gone to a massive amount off effort to drive that home so make sure there's sufficient support elsewhere
Has thanked: 810 times
Been thanked: 3500 times
Cut it off flush.
Grendel
Has thanked: 201 times
Been thanked: 501 times
Post by Grendel »
Another way to remove it using a claw is to put the nail in the claw and with one hand on the striking face use the other to push on the handle sideways , refitting the claw onto the nail and pushing in the opposite direction and so on. The nail comes out bent to buggery but it does come out.
hiace_drifter
big-all wrote: Mon Sep 11, 2023 1:33 pm someone has gone to a massive amount off effort to drive that home so make sure there's sufficient support elsewhere
If you mean make sure it is not hioding anything up ...
Some 4 inch mock tudor beams had been attached to the porch beams using these nails. Most came off with the beams, but this one pulled through the beam and stayed in situ. So it is not holding anything up or in place.
ahh ok makes sense just ignore my thoughts :lol:
What ever you do, don't bite it, my (late) mum was always telling me "son, don't bite your nails" :-)
hiace_drifter
Someone-Else wrote: Tue Sep 12, 2023 3:14 pm What ever you do, don't bite it, my (late) mum was always telling me "son, don't bite your nails" :-)
very good advice ;)
I have now got them out ... managed to bend them over and manhandle them out.
Return to “General DIY forum”
