Hi all , I am looking to source some 50mm diameter Drill bits. Preferably long auguer bits.
Any help would be great !!
Auger Drill bits
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2559 times
Auger Drill bits
Posting in the correct forum would be a good start, I will just press this button..........
- Has thanked: 807 times
- Been thanked: 3498 times
Auger Drill bits
Depends on what you want it for. A flat bit will chew through quickly, a Forstner bit will make a smooth precise hole slowly, and a hole saw will work. Tells us the job for the best guidance.
Auger Drill bits
Hi , I am looking to for a 50mm Auger drill bit to be able to drill 50mm to place steel balustrades for glass stairs.
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 566 times
Auger Drill bits
Is that in wood? A hole saw would probably be more precise depending on how deep you have to go. If it is a blind hole a Forstner type bit might be better. You need to spend a bit of time explaining what the job is.
