Rubber mixing bowl maintenance
ikehgl
Post by ikehgl »
For general wall plastering jobs in the house I use a rubber mixing bowl.
After several uses, and thorough cleaning of the bowl, it loses its flexibility and round shape.
It looks like it was pushed on the sides and I end up buying another one.
Is there a way to prevent it from getting hard and deformed, such as rubbing with oil, etc. ?
Has thanked: 47 times
Been thanked: 2590 times
Sounds like a plan, BUT some types of rubber do not "get on" with some types of oil. There is also the question of what is your bowl really made of? then you would need to find a lubricant suitable, then the question would be how much is said lube?
Probably easier and cheaper to buy a new bowl
One of these Click me
Or
Neither are rubber
ikehgl
Post by ikehgl »
I'm talking about a hand held bowl, about 20 cm. across
oh, ok, still almost the same answer though.
There is also the question of what is your bowl really made of? (You may think its rubber, but it might be a type of flexible plastic)
Also you would need to find a suitable lubricant. (One that will not harm your bowl)
You can either do trial and error (wasting money on lubrication that does not achieve what you want) Or contact the manufacturer of your bowl.
If there is such a lubricant you have to ask how much is said lube? Will it cost more than a new bowl?
Probably easier, less hassle and cheaper to buy a new bowl
Sorry it is not the definitive answer you were looking for.
Has thanked: 824 times
Been thanked: 3564 times
Put a bin bag in it as a liner
Return to “Plastering Forum”
