Anyone know what this is?
Hi all, I wasn’t sure which section to put this into but this stuff keeps peeling off onto my floor and just wondering what the cause/remedy would be? Images included to what I am referring to. Obviously the radiator hasn’t been turned on for a long time now, wouldn’t think it’s related to that, I really have no clue what it is or the cause so any help would be most appreciated.
- IMG_0929.jpeg (447.61 KiB) Viewed 1143 times
- IMG_0927.jpeg (488.4 KiB) Viewed 1143 times
- IMG_0928.jpeg (487.09 KiB) Viewed 1143 times
- IMG_0932.jpeg (412.11 KiB) Viewed 1143 times
- IMG_0931.jpeg (548.06 KiB) Viewed 1143 times
- IMG_0934.jpeg (456.77 KiB) Viewed 1143 times
- IMG_0933.jpeg (357.81 KiB) Viewed 1143 times
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 566 times
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2564 times
Peeling off from where? (You don't say)
That’s the thing I can’t decipher? It’s a total mystery to me where it is emanating from, just hoped someone may have come across this before?
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
my best guess would be summat put on behind the radiator to reflect heat back in the room that has broken down.
Can you get a torch down behind the radiator ?
Just tried to look down the back with a torch, can’t see anything obvious so it’s a mystery
- Has thanked: 810 times
- Been thanked: 3500 times
Actually T that might be it. Is it a thermal layer in the curtains breaking down. It could have dried out over time and got brittle.
- Has thanked: 104 times
- Been thanked: 2 times
Looks like what just happened to me. I was given some of those curtains with the rings already in them to thread over the pole I think they are called eyelet. Turns out it is the interlining for the section where the rings are attached
